AVEVA Plant SCADA – Automatic Switching to the Primary NUA100 Module in M580 Hot Standby Architecture
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • AVEVA Plant SCADA – Automatic Switching to the Primary NUA100 Module in M580 Hot Standby Architecture
  • RobertSanders
    RobertSanders
EcoStruxure™ Control Expert
Citect SCADA
AVEVA
AVEVA™ Plant SCADA
Back to Industrial Automation Knowledge Base
Lt. Commander RobertSanders Lt. Commander
‎2023-12-23 01:18 AM
on ‎2023-12-23 01:18 AM
In a M580 Hot Standby architecture the BMENUA0100 Module does not swap IP addresses like the other communication modules, therefore the SCADA system has to independently detect which NUA module is Primary.
The aim of this document is to provide a step-by-step guide for configuration of AVEVA Plant SCADA (Citect) communicating to the BMENUA0100 Module using OPC UA Client and M580 Hot Standby.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Material.7z
Rate this article:
100% helpful (1/1)
