Creating a bootable media with the ITA ISO
ITA installation and setup
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA installation and setup
  • Creating a bootable media with the ITA ISO
  • Mark as Read
  • Recommended IT Advisor desktop client configuratio...
  • Upgrading from DCO 8.x to IT Advisor
  • Installing the ITA server using out-of-band manage...
  • Installing ITA in a location without public Intern...
  • Installing IT Advisor in a virtual environment
  • Installing IT Advisor (on-premises)
  • How to download Data Center Expert and IT Advisor ...
  • Configuring disaster recovery
  • Changing the location of the IT Advisor client tem...
  • Initial setup for a new ITA installation
EcoStruxure IT Support
Request Support
Back to ITA installation and setup
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-14 08:34 AM
ITA can be installed using a bootable USB key containing the ITA installation.
On a Windows machine
On Windows one way of creating a bootable USB key is using the free tool, Rufus.
1. Download and install Rufus here: https://rufus.akeo.ie/
2. Insert your USB key and run Rufus.
3. In Device, select your USB key.
4. Click the disk icon (see screenshot), and select the ISO file, then click Start.
5. Select Write in DD Image mode, then click OK to replace all data on your USB key with the ITA installer files.
6. Wait for the process to complete and click Close.
7. Eject the USB key from Windows before removing the key (e.g. in Windows Explorer right-click the USB key, and select Eject).
On a Mac machine
Run the dd command as described below.
  1.  Insert your USB key and open Disk Utility on your Mac.
  2. Select your USB key, and find the USB device name (see screenshot).
  3. Open Terminal and navigate to the folder with the ITA ISO file (e.g. cd Downloads).
  4. Type sudo dd if=EcoStruxureITAdvisor-<version number>.iso of=/dev/<usb device name from step 2>
  5. Wait for dd to finish and remove the USB key.
On a Linux machine
  1. Insert your USB key and open your favorite console program.
  2. Type dmesg and find the USB device name, such as sdb (see screenshot).
  3. Type sudo dd if=EcoStruxureITAdvisor-<version number>.iso of=/dev/<usb device name from step 2>
    Ensure you select the device as destination (e.g. /dev/sdb) corresponding to the USB key and not a partition (such as /dev/sdb1).
  4. Wait for dd to finish and remove the USB key.
Output of dmesg, showing USB device name
