Configuring disaster recovery
ITA installation and setup
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA installation and setup
  • Configuring disaster recovery
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to ITA installation and setup
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-14 08:34 AM
Last Updated: Sisko JLehr Sisko ‎2024-04-05 11:07 AM
Note: Licensing for one disaster recovery node (DR) is part of the IT Advisor base license.
In this example of configuring IT Advisor disaster recovery, two stand alone servers have been created, Server1 and Server2. Server2 will be configured as the disaster recovery node to Server1.
IMPORTANT: If the Disaster Recovery node is monitored by Data Center Expert via SNMP, it is important to set the device scan timeout in DCE high enough for the Disaster Recovery node to respond. Otherwise, it will return a communication lost status. How you set the device scan timeout depends on the network speed between the Disaster Recovery node and the ITA server.
Configure Server 1
  1. Log in to the Server1 Webmin interface, and select EcoStruxure IT Advisor > Disaster Recovery.
  2. Select Allow another node to connect to this node.
  3. In Allow the following IP as disaster recovery node, enter the IP address for Server2.
  5. Check Accept fingerprint then click Allow.
Once the fingerprint is added successfully, follow the on-screen instruction to go to Webmin for Server2 to continue the setup.
Configure Server 2
    1. Log in to the Server 2 Webmin interface and select EcoStruxure IT Advisor > Disaster Recovery.
    2. Select Attach this node (xx.xx.xx.xx) as a disaster recovery node to another node. ITA_1_360036883074.pngITA_1_360036883074.png
    3. Enter the IP address for Server1 in Attach this node to the following IP: ITA_2_360036883074.pngITA_2_360036883074.png
    4. Click Attach. ITA_3_360036883074.pngITA_3_360036883074.png  img_04_360036883074.JPGimg_04_360036883074.JPG
    5. Check Accept fingerprint. ITA_1_360036883074.pngITA_1_360036883074.png and then click Attach.ITA_2_360036883074.pngITA_2_360036883074.png
While the node is successfully being attaching, the notification is Attaching the node, please wait this could take several minutes......
Please watch the status page to monitor progress.
The Server1 Status page displays information for both itself and Server2 as Disaster Recovery.
The Server2 Status page displays information only about itself as Disaster Recovery.
Upgrading a disaster recovery setup
Upgrade both the master node and the disaster recovery node to the new version of IT Advisor.
