Changing the location of the IT Advisor client temporary files
ITA installation and setup
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA installation and setup
  • Changing the location of the IT Advisor client temporary files
  • Mark as Read
  • Recommended IT Advisor desktop client configuratio...
  • Upgrading from DCO 8.x to IT Advisor
  • Installing the ITA server using out-of-band manage...
  • Installing ITA in a location without public Intern...
  • Installing IT Advisor in a virtual environment
  • Installing IT Advisor (on-premises)
  • How to download Data Center Expert and IT Advisor ...
  • Creating a bootable media with the ITA ISO
  • Configuring disaster recovery
  • Changing the location of the IT Advisor client tem...
  • Initial setup for a new ITA installation
EcoStruxure IT Support
Request Support
Back to ITA installation and setup
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-14 08:34 AM
You may want to change the location of the temporary files for a number of reasons that the company policy leaves limited space in the user profile folder.
Recommendation:
Do not move the temporary files to a location on your network drive as you will experience decreased performance.
Windows 10
By default, the temporary ITA files are stored here: C:\users\<username>\.isxo
You can change this location in the .config ini file stored in the program files:
  1. Browse to C:\Program Files\<IT Advisor version>\application\configuration
    Program Files is the default location. If you are running 32bit, the location is Program Files (x86).
  2. Open the config.ini file in a text editor, such as Notepad++.
  3. Edit the path in these two lines from @user.home/ to a location of your choice, for example to the root c:/:
    osgi.instance.area=@user.home/.isxo/<version number>/Operations
    osgi.configuration.area=@user.home/.isxo/<version number>/Operations
