Room colo overlay
ITA colo desktop client (on-premises only)
  • EcoStruxure IT Help Center
  • IT Advisor
  • Tenant and colo
  • ITA colo desktop client (on-premises only)
  • Room colo overlay
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to ITA colo desktop client (on-premises only)
  • Mark as Read
Room colo overlay
Picard EcoStruxureIT
‎2019-10-14 05:15 AM
The selected overlay defines what information is shown on top of the layout. You can switch to see the room layout in another overlay by selecting another overlay tab at the bottom of the room layout pane. In Window > Show Overlays, you can define which overlay tabs to enable.
The Colo overlay of the data center shows you information on space and rack count. The color highlights will give you insight as to whether a rack or a floor space is open, reserved, closed, internal, or a customer state you define. See Configuring colo states
Rack default states
102237291_16x25_360036863854.png102237291_16x25_360036863854.png Open: The rack is empty
102237317_16x25_360036863854.png102237317_16x25_360036863854.png Reserved: The rack is reserved for a customer, but the customer is not using it yet. To reserve a rack go to the Planning tab, right-click the rack, select Customer and Reserved for potential customer
102237319_16x25_360036863854.png102237319_16x25_360036863854.png Closed: A customer is using the rack
102237289_16x25_360036863854.png102237289_16x25_360036863854.png Internal: The rack is booked for internal use. In the Planning tab, right-click the rack and select Properties > Customer. The customer is an internal user.
Floor Space
102237291_16x25_360036863854.png102237291_16x25_360036863854.png Open: The available amount of your sellable space
102237317_16x25_360036863854.png102237317_16x25_360036863854.png Reserved: The reserved amount of your sellable space
102237319_16x25_360036863854.png102237319_16x25_360036863854.png Closed: The used amount of your sellable space
102237289_16x25_360036863854.png102237289_16x25_360036863854.png Internal: The amount of your sellable space that is for internal use
Room Area: The area of the room
Sellable Space: The sum of your all states beside internal one. Your internal space is not sellable and therefore not a part of the calculation.
Space Efficiency: The ratio between your room area and your sellable space.
Go to Tools > Configure Customer States. Set the name and color for each state.
Four default states (Open, Closed, Internal, Reserved) can't be renamed or deleted.
When a new state is defined, it can be assigned to equipment in Customer properties.
See IT Advisor for Colo desktop client
