Scheduling regular backup jobs
ITA backup and restore
Send InviteCancel
When you have created the backup configuration, you can set up the system to automatically backup regularly according to your backup strategy.
The regular backup files will consume some disk space and increase in size over time, so it is highly recommended to use a remote location. See how to clean up old backups here.
Open the Webmin web interface by selecting Administration>Webmin in the ITA web client. Alternatively, type the address of your ITA server in a Web browser followed by :10000, <https://>:10000 .
Log on to Webmin using the user credentials created during installation of IT Advisor.
In the left menu, select System>Scheduled Cron Jobs.
To enable the default backup schedule:
Select one of the 3 backup options as needed:
Daily
Weekly
Monthly
Click Enable Selected Jobs to enable the job with the default settings. Note that per default the daily backup option is enabled.
To customize the backup schedule:
Click one of the 3 backup IT Advisor server options (click in the "Command" column) as needed:
Daily
Weekly
Monthly
Edit the time for the system to automatically execute the backup job as needed. By default daily backup runs at 2:30 AM.
Select Active: Yes and save to enable the selected backup job. The system will automatically run the job regularly with the specified interval.
