ITA web service API
ITA advanced use
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA advanced use
  • ITA web service API
  • Mark as Read
  • Web proxy server setup guide for ITA
  • Resolving error collecting data
  • ITA desktop connection through proxy
  • How to manually create a CSR (certificate signing ...
  • External User Access
  • Correcting False Power Values Reported by Data Cen...
  • Changing the SSL certificate on the ITA server
EcoStruxure IT Support
Request Support
Back to ITA advanced use
  • Mark as Read
ITA web service API
Picard EcoStruxureIT
‎2020-03-18 11:43 PM
The EcoStruxure IT Advisor Web Service API is a set of web services that provide access to various parts of IT Advisor.
The RESTful web service documentation is available on your EcoStruxure IT Advisor server at https://<server-IP>/api/current/docs/index.html
Use the system administration credentials you use when logging into EcoStruxure IT Advisor.
Accessing the API documentation on your EcoStruxure IT Advisor server allows you to easily test the endpoints.
50% helpful (1/2)
