Changing the SSL certificate on the ITA server
ITA advanced use
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA advanced use
  • Changing the SSL certificate on the ITA server
  • Mark as Read
  • Web proxy server setup guide for ITA
  • Resolving error collecting data
  • ITA web service API
  • ITA desktop connection through proxy
  • How to manually create a CSR (certificate signing ...
  • External User Access
  • Correcting False Power Values Reported by Data Cen...
EcoStruxure IT Support
Request Support
Back to ITA advanced use
  • Mark as Read
Picard EcoStruxureIT
‎2020-03-16 06:49 PM
The ITA server is installed with a self-signed security certificate. When you connect to the server from a web browser, you might receive warnings about the security certificate. It is recommended, after the ITA installation is complete, that you purchase and install a security certificate issued by a trusted certificate authority.
To change your SSL certificate on the ITA server, the certificate must be the Apache 2.x/PEM format with two files: *.key, *.crt.
See How to manually create a CSR (certificate signing request) from an IT Advisor server
It is best practice to disable access to the web clients before you update any certificates to make sure no client is connected with a false certificate.
If your setup includes a disaster recovery node that needs a certificate, upload certificates to the DR server the same way as for a standalone server.
Preparing a certificate for upload
Password
A password protected key is not supported. Strip the password from the key before uploading it.
Intermediate or certificate bundle
If your certificate chain requires an intermediate certificate, append it to the .cert file. When appending, make sure you include everything, including the lines: "-----BEGIN CERTIFICATE-----" & "-----END CERTIFICATE-----" There may be several lines for this intermediate certificate.
No users in the system during upload
The Apache HTTPD server will be reloaded during this process, so make sure no users are using the system during the upload.
Uploading a certificate
  1. Open the Webmin web interface by selecting Administration > Webmin in the IT Advisor web client.
    Alternatively, type the address of your EcoStruxure IT Advisor server in a Web browser followed by :10000, https://<ITA server IP>:10000 .
  2. Log into Webmin using the user credentials created during the installation. Select EcoStruxure IT Advisor in the left menu.
  3. In the submenu, select Certificates.
  4. Follow the instructions on the page.
  5. Verify that everything is working correctly. Launch a web client and check that there's a green pad lock icon in the address line.
webmin_certificates_option_360006707217.JPGwebmin_certificates_option_360006707217.JPG
