Posted: 2021-06-09 06:33 PM
Hi Guys,
I am planning to implement a "Child lock" screen or lock screen after a x period of inactivity. I have an idea using the backLight timer to trigger a local timer which launch a pop-up screen which I design already. My question is in regards the system flag or timers documentation. I haven't found a proper documentation about those topics. Any ideas???
I much appreciate your suggestions,
Posted: 2021-06-10 12:02 AM
You can find in the follow link an example how you could start a procedur regarding to inactivity
And you could check in you code the value of sysBacklight.
0 = Min Backlight active
1 = Backlight on
2 = Timer are running
You can adjust the time for sysBacklight via Par_BackLIghtTime
Posted: 2021-06-22 06:25 PM
Thanks for your advise. Finally, I used a structure call sysLCDPressed which triggers a timer. I could not find any documentation about this, I just tried and worked.
1 = Backlight on
