new program for control a suction with 10 entries
HVAC and Pumping Forum
Send InviteCancel
Posted: 2023-10-0304:10 AM. Last Modified: 2023-10-0304:17 AM
Hello all .
i need to create a new program for an SR3B261BD to control a suction turbine .
in this machine we have 10 entries controlled by solenoid valve .
we need to detect wich valve is actionned , so we closed all valves except the actionned .
we wait 3 second , then activate the turbine for a time in fonction of wich valve is actionned .
during the time the turbine is working and the 3 seconds of wait to charge the vlaves , if another input is actionned , we need to add the corresponding time to turbine ( without stopped it ) and close all valves except the new one for the added time , and let the time for previous actionned entrie to finish .
if the valve actionned is actionned multiples time , do nothing more than wait 3 seconds and activate turbine for the time given by the corresponding entrie .
