Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
Posted: 2025-03-15 12:10 PM
How to clear retentive timer memory %MW after stoping while timer not finished counting in ecostuxure machine expert basic?
Posted: 2025-04-16 12:04 AM
Hi @alpikon
I'm not sure if I got your question:
As soon you deactivate IN, the current time counting goes to zero.
Also, if you want to ensure after a power cycle that counting is not retained, you must unflag "Retentive"
Posted: 2025-04-17 12:37 PM
At the moment I found one solution: (SB Coldstart) %Sx
That's let when counting stopped by reason and needs re-start timing over gain from 0.
Posted: 2025-05-02 10:20 PM
Hi, you can manually reset the retentive timer’s %MW memory by adding a line in your code to set it to zero when the machine stops or on a reset condition. Use %MWx := 0;
where %MWx
is the timer memory word.
