Vijeo Designer Simulation Input Field Problem
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Vijeo Designer Simulation Input Field Problem
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Posted: ‎2022-03-05 04:11 PM
I have designed a program in Machine Expert using M241 PLC, and also designed HMI using Vijeo designer. Everythings seems to work when I start the simulation, exept when I try to write a value to the input field. In this case, I get the notification Failed to open communication with PLC. it is strange since the same field shows the right values when they are sent from PLC simulation.
Can anybody help me, please?
Replies 0
