Simulation M172(Modbus TCP server) and HMIST6400
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Simulation M172(Modbus TCP server) and HMIST6400
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EdwardKul
EdwardKul
Explorer
Posted: ‎2025-07-18 06:53 AM
882
Hello, please tell me, is it possible to simulate simultaneously on a PC controller M172 (configured Modbus TCP server) in EcoStruxure Machine Expert - HVAC and HMIST6400 operator panel in EcoStruxure Operator Terminal Expert? And how can this be done?
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-07-21 12:39 AM
at the moment it is not possible, but I will forward this request to Mkt department
FedericoM
FedericoM Mentor
Mentor
Bastian_Schmitz
Champion
Posted: ‎2025-07-22 11:53 PM
At the moment the only possibility is to connect a TM172P via Modbus TCP to your PLC, in that case the Simulation of EOTE could connect to the PLC. In that case you need some phyiscal hardware to control Inputs on plc site. And the PLC need 24V, 5V via USB is not enought.
