Should I worry about output Ambere rating on Voltage Stabilizer
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Should I worry about output Ambere rating on Voltage Stabilizer
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Posted: ‎2021-10-11 12:21 AM . Last Modified: ‎2021-10-17 10:52 PM
2413
Electricity supply in my home town in so bad that it fluctuate every 30 second going down by 50 to 70 volts from standard 230V and comes back to the standard voltage at the same second. I'm using an APC UPS and it clicks all day(AVR) and it is quite annoying. I'm looking for a voltage stabilizer to use with my UPS which require 200 to 240V at 6A. But the stabilizer I found outputs 200-240 V at only 2.5 A. Is this going to be an issue? is it going to hurt my UPS and my PC. If not why?
Omegle
  • Safety
Posted: ‎2021-10-29 02:02 AM
The stabilizers get this done by using an electronic circuitry, which changes the required taps of an inbuilt auto transformer with the help of high quality electromagnetic relays to generate the desirable voltage. If the Voltage to be supplied is not within the range, a mechanism switches the required transformer tap, thereby bringing the Voltage supply within a safe range.
Thus the stabilizer acts as a safe guard between your equipment and utility, by continuously monitoring and stabilizing the voltage fluctuations that appear in the utility. It ensures that your valuable appliance receives a consistent stabilized range of voltage as its input for a trouble free operation and long operational life.
  • You should also consider the surge current which flows when you switch on the device.
  • In case the Voltage Stabilizer has a rating in watts also, assume a power factor of 0.8 (W=V*A*pf).
The most important thing is to know the nature of the load connected to the stabilizer. First you must note down the power (or Watts) for all the appliances that will be connected to a stabilizer. The sum total of the power consumption (or Watts) will give you the load on the stabilizer in watts. But most stabilizer sizes are in VA (Volt Ampere) or kVA (kilo Volt Ampere which is equal to 1000 Volt Ampere). Although to get the actual VA (or Volt Ampere) from Watts (W) you will have to do some measurements, but to give a rough approximation, you can increase the Watts value by 20% to get the approximate VA size that you may need.
shaglechatspin
