Regarding Machine Expert V1.2.11 Issue
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Regarding Machine Expert V1.2.11 Issue
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert
StevenCho
StevenCho
Contributor
Posted: ‎2024-04-08 02:33 AM
1821
Hello all,
I faced with a IP set issue of M251 with Machine Expert Version 1.2.11 (Which is V1.1 License)
Issue : IP address is changed to that I've never set up.
I proceeded in the following order.
  1. PC ↔ M251 : Download program via USB MINI-B(Disconnect cable after complete)
     : ETH1 IP : 192.168.0.141 / 255.255.255.0
     : ETH2 IP : 192.168.10.141 / 255.255.255.0
  2. PC ↔ M251 : Scan network via Ethernet. After scanning, Login(Connect) to 192.168.0.141.
  3. After power reboot,
     :  IP address is changed to 11.11.190.79 / 255.255.255.0
     : sometimes it is recovered its IP address what it should be.
I tested 5 of TM251MESE.
And this happened always with M251 PLCs.
And this issue is solved right after by using Machine Expert V.2.0
I am pretty sure, there is software issue on V1.2.11.
Is there any plan to fix the issue?
If not, Is there any plan to release upgrade license?
Thank you🙂
  • Material Handling
  • ESME
  • Machine Expert
MathAutomation
MathAutomation
Explorer
Posted: ‎2024-04-09 04:19 AM
1790
Hi, maybe this could help you, have you tried changing the ip address from the controller assistant software by changing the firmware? There's a communication settings section. Maybe that could help.
StevenCho
StevenCho
Contributor
Posted: ‎2024-04-11 11:59 PM
In response to MathAutomation
Thank you, I will try.
Did you experienced something like this before?
StevenCho
StevenCho
Contributor
Posted: ‎2024-04-23 09:24 PM
Is there anyone can help me to be convinced?😂
I am unconvinced with the answer from local team.
They told me that do not use V1.1 for the new project but only for maintenance.
(Even though I use this only for maintenance, the issue is still unresolved..)
Is the official notice from Schneider Electric?
