M340 AND SIEMENS S71500
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M340 AND SIEMENS S71500
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Posted: ‎2022-09-21 11:36 AM
2986
I need to establish communication between Schneider M340 and S7-1500 PLC.
I am using gateway converter for MODBUS TCP TO PROFINET protocol conversation. I just do not how to do programming/configuration in unity pro.
please help me if anyone has ideas. @Anonymous user
  • Connectivity
Marian_Pavlik
Marian_Pavlik Troubleshooter
Troubleshooter
Posted: ‎2022-11-15 01:49 AM
It depends on what role should M340 take at Modbus TCP side.
What is gateway role on Modbus TCP side? Client or Server ?
If Gateway is Modbus TCP Client
- by default M340 has open Modbus TCP Server role. No need to program. All located %MW and %M memory is open to Read/Write.
If Gateway is Modbus TCP Server
- M340 could be Modbus TCP Client by
  - BMXNOE0100 module with IO scanning feature to provide effective cyclic communication with Modbus TCP servers defined by few parameters in rows.
  - if no NOE module to use READ_VAR, WRITE_VAR FBs in code
There is Modbus TCP - MB_Client FB in TIA S7-1500 so no need to use gateway.
