M172 modbus TCP limits
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 modbus TCP limits
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Kleroman
Kleroman
Contributor
Posted: ‎2023-08-11 03:58 AM
2131
How many maximum devices can poll the M172(SLAVE) controller via ModbusTCP?
I have 8 HMI panels(Master) and one M172(Slave).
Bastian_Schmitz
Champion
Posted: ‎2023-08-13 10:51 PM
Hi Kleoroman,
You could see here the default number of open sockets for Modbus TCP
And you can add maximal 3 additional
In your case you could try if a higher delay time between read commands could work. If you use continous read via HMI it could be a problem.
Bastian_Schmitz
Champion
Hi Kleoroman,
