M172 SNTP day of week and GMT
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 SNTP day of week and GMT
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
rfond
rfond
Contributor
Posted: ‎2023-04-04 10:57 PM
1619
Hello everybody,
Little question to follow up about a request to have SNTP Time :
(https://community.se.com/t5/Machine-Automation-Forum/SNTP-with-M172/m-p/428939#M886)
Is there a functional block to get the day of week with full date ?
Is there a functional block that determines the time zone ?
My Code :
FC_TON_Time(IN:= NOT FC_TON_Time.Q, PT:= 60000);
IF FC_TON_Time.Q THEN
sysSNTP_Reset();
END_IF;
usiSNTP_Status := sysSNTP_GetTime(FALSE, 123, 192, 168, 253, 2, ADR(usiSeconds), ADR(usiMinutes), ADR(usiHours), ADR(usiDay), ADR(usiMonth), ADR(usiYear));
R_TRIG_Update(clk := usiSNTP_Status = 3);
IF R_TRIG_Update.Q THEN
sysClockWrite(usiSeconds, usiMinutes, usiHours, 0, usiDay, usiMonth, usiYear);
END_IF;
Thank's you very much.
  • HVAC
  • M172
Bastian_Schmitz
Champion
Posted: ‎2023-04-04 11:07 PM
1615
yes there is a block available, check the attached file.
dayweekcalc.zip
Bastian_Schmitz
Champion
1616
dayweekcalc.zip
rfond
rfond
Contributor
Posted: ‎2023-04-04 11:40 PM
In response to Bastian_Schmitz
Work's very good for day.
Any solution for GMT ?
