How to use PIDAutoTunning block in EcoStruxure Machine Expert - HVAC ?
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • How to use PIDAutoTunning block in EcoStruxure Machine Expert - HVAC ?
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
Felipe_Lima.99
Felipe_Lima.99
Explorer
Posted: ‎2025-04-22 07:06 AM
1729
I have an M172 controller and couldn't find any examples of how to use the PIDAutoTuning  block. Has anyone been able to implement it? I tried several ways but I was not successful. No errors appeared when compiling but the block did not generate the values ​​"automatically".
  • HVAC
Bastian_Schmitz
Champion
Posted: ‎2025-04-23 10:32 PM
You could find an example in the included TVDAs.
Bastian_Schmitz_0-1745472487761.pngBastian_Schmitz_1-1745472516453.pngBastian_Schmitz_2-1745472594486.png
After the autotune you have to store the values manually in the EEPROM. You wil find an example also in the TVDA project in the next network.
How good the autotune works depends on your system. In my personal expirience it works mostly good with actuators which could use the full operation range without any external influence. As example an 2 oder  way water regulation valve works good. A condenser fan could be complicated because you could run in a high pressure fault during tuning. You have to try it.
Bastian_Schmitz
Champion
Josh1
Josh1
Explorer
Posted: ‎2025-08-11 10:14 PM
Hi, @Felipe_Lima.99, Did you find the bug/solution which was causing "No errors appeared when compiling but the block did not generate the values ​​automatically".? Thanks!
