How to Create BACnet Alarm in EBO for M172 Controller
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • How to Create BACnet Alarm in EBO for M172 Controller
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
summersiu
summersiu
Contributor
Posted: ‎2021-05-04 08:04 PM
2344
I created notification class in Machine Expert HVAC. But I cannot find where I can create BACnet Alarm to use the class. So I discovered the M172 in workstation and tried to create in workstation. However, warming " object dynamic creation not supported".
My question are:
1) How can I use the notification class (I know this class is used for BACnet Alarm)
2) How can I create object in workstation
3) If I can create the object in workstation, will I also observe these object in Machine Expert - HVAC?
Thank you
  • HVAC
summersiu
summersiu
Contributor
Posted: ‎2021-05-04 11:09 PM
2341
Updated:  Now , I already know how to apply the notification to each point. However, the alarm state is always shown "normal" but the event state show normally (High limit or Low Limit as what I expected) , How can I change to apply the notification?
Linh_LD
Linh_LD
Explorer
Posted: ‎2021-08-21 03:13 AM . Last Modified: ‎2021-08-21 03:15 AM
In response to summersiu
Hello @summersiu
Can you write value from EBO to Status Variable or EPPROM using BACNET/IP?
I'm just got the value (on Eco HVAC) but can not write to Status variable
Can you help me?
