HVAC HMI error Cl6385
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • HVAC HMI error Cl6385
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
Draad
Draad
Explorer
Posted: ‎2024-01-16 07:31 AM
1925
after installing the Machine expert HVAC I received an error after compiling the Display program.
It is error: kStr00101(804) - error C16385: kStr00101 => Invalid init value.
Who knows what the cause is and how to solve?
Thanks.
  • HVAC
Replies 5
Bastian_Schmitz
Champion
Posted: ‎2024-01-16 11:25 PM
1921
On which target do you have the problem?
The error occours if you define an incompatible init value for an variable.
I would expect something went wrong on one of your last modifications.
best regards
Draad
Draad
Explorer
Posted: ‎2024-01-17 12:14 AM
In response to Bastian_Schmitz
The target is an M172 with build-in display.
The application was written in a 2 years old ME HVAC.
When I opened it in the latest ME HVAC there was a message if I would like to update.
I tried to update and no update both gave the same issues.
When I removed the edit fields the next 10 errors came up.
It seems that all edit field are giving the same error.
Best Regards ,
Bastian_Schmitz
Champion
Posted: ‎2024-01-17 09:57 PM
1903
If you remove the first edit field the next ten show the same error?
If you remove all edit field the project could be compiled?
It sounds for me like the interaction between variables an display part generate the problem.
Did you try to remove and add all variables via the HMI Vars tab?
Alternative you could try via Projecta refresh target
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2024-01-18 11:41 PM
1
1885
the error is due to a bug of this version. You probably have a ' used in a text field with an explicit string.
The workaround is define the same string in the String Table
rfond
rfond
Contributor
Posted: ‎2024-03-14 02:06 AM
In response to FedericoM
I have the same problem, deleting ' is a good solution
