Posted: 2023-01-06 02:42 AM
Dear All need support,
Please refer to the above subject, data binding layout Object Grid "rows" and "column" insert with texts not working i.e cannot insert data into rows and column.
>>Grid Properties?
Please assist.
Posted: 2023-01-06 04:46 AM
Hi @Mtoto ,
I am not 100% sure if i understood your question but once you add the object "grid" into a screen you will need to configure the amount of row and columns. Then you will need to add objects to those areas.
So if you need to insert a text then first click on the grid then select from the "toolChest" the "text box" and drag&drop into the grid.
Best regards,
Posted: 2023-01-06 09:20 AM
Hi Le Tomas,
Thankyou for the feedback, from your response it seems that you have understood my query, still I can restructure my question again:-
After inserting the Grid object on the Screen and formats the properties number of "raws" and "columns" for the grid then realized that there were no properties to access ROWS|COUMNS and insert data into the grids directly i.e either TEXT Object or Images.
Then I move forward by inserting text objects & Images like your proposal above however when the screen scroll MOVE the grid Rows not aligned to the same location (x:y) i.e overlap objects TEXT OBJECT embedded ontop miss alignment with the ROWS on the grid object
Posted: 2023-01-10 08:05 AM
Hi Le Tomas,
Thankyou for support will come back to this later
