Control Expert References
HVAC and Pumping Forum
Send InviteCancel
Posted: 2022-09-0407:52 AM
Hi all
I'm just starting out with referenced variables in Control Expert (15.0 SP1), and I've run into a problem: I have followed an example from the Faqs, where it is explained how to reference a variable but, when compiling the code, I find the message; "Initial value access rights are not supported. : Motor_1.Feedback" (The Feedback variable is associated with an analog input) The variable has read/write permissions (program R/W). Any suggestion?
