Block number priority in Zelio and Is is possible to renumber blocks ?
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Block number priority in Zelio and Is is possible to renumber blocks ?
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
kurtklingbeil
kurtklingbeil
Explorer
Posted: ‎2023-10-30 11:42 PM
While codebashing in Zelio I noticed some anomalies in the behaviour of DISPLAY blocks
with further poking and prodding I have pretty much come to the conclusion that
blocks write to the display in block-order sequence
So, if there are "collisions" or overlaps, the highest block order "triumphs in glorious victory".
I think it would be beneficial to indicate that in the manual / help for DISPLAY.
My approach ended up writing an initial text block which wrote to the entire 4x18 character array
Then, in subsequent blocks, I write the variables in the appropriate spots.
Occasionally, when space gets tight, I may write a variable, and then afterward selectively
overwrite the text indicating the units and perhaps some of the leading +00 of the fixed-width
variable format.
I had questioned whether there was some way to renumber blocks - given the tools with such names,
but I discovered that this tool is highly non-selective and cannot be used to  change the order of blocks.
I just end up creating a new DISPLAY block which will have a higher block number...
Here's a generator loadbank controller I banged together
It reads the phase currents from 4-20mA current transformers and does the math...
  • Efficiency
  • Material Handling
Replies 0
