BACnet Binary Value/Input on M172 PLC
HVAC and Pumping Forum
Send InviteCancel
Posted: 2025-05-2308:07 AM. Last Modified: 2025-05-2308:07 AM
I need to share values from my PLC over BACnet and I have the analog working as I imported the "AI" template, but there is no template for "BI", only "BV". When I try to change from BV to BI the drop down is greyed out. How do i share BACnet Binary Input objects with M172 PLC to a BMS.
