Reading TH110/CL110 realtime data using PAS600's internal wifi+webserver
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Reading TH110/CL110 realtime data using PAS600's internal wifi+webserver
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
Lowell
Crewman Lowell Crewman
Crewman
Posted: ‎2025-10-17 07:44 AM
248
I have Th110 and CL110 installed in my ring main unit RM6.
I intend to use PAS600 as data concentrator and connect my mobile phone via PAS600 internal wifi.
Will I be able to access its embedded web server thru my mobile phone to read real-time data, do configuration, and diagnostics?
If it will work, do we have a procedure to set-up this and do I need more external device to make it work?
Thanks for the support
Kr
Lowell
  • Product selection
Tags (6)
  • CL110
  • PAS600
  • th110
  • webserver
  • wifi
Guillaume_Evrard
Captain
Posted: ‎2025-10-19 09:56 PM
hello @Lowell
When TH110/CL110 are paired to the PAS you will be able to get temperature readings + humidity inside the web pages.
Are your TH/CL in your RMU provided with a zigbee dongle and working with Thermal App (former name) or Power Device on your smartphone ?
If yes you have to unpair the sensors from the APP and pair them to the PAS.
If you have a Zigbee gateway (ZBRN32, or PAS) just need to add the PAS in case of ZBRN32.
Kind Regards
Guillaume_Evrard
Captain
hello @Lowell
Kind Regards
Lowell
Crewman
Posted: ‎2025-10-20 10:52 PM
Thanks for advising that this is a viable solution; very helpful
Kr
Lowell
