| User | Count |
| 116 | |
| 58 | |
| 46 | |
| 32 |
Hi Xperts,
Just want to ask if the below cable can be used for RS485 cabling (PAS800L to meters).
Jedz
Hi Jedz @jedzruiz1985
Would suggest you to follow the instruction sheet specification.
And for further detailed wiring instruction, you can find from here https://www.se.com/in/en/faqs/FA221785/
Hope this helps!
hello,
Even this is not a belden certified modbus cable for RS485, It will depend on the length of the cable.
From what I see this is twisted pair, with overall shield/screen so should be OK.
For small distances LAN cables can be used.
Kind Regards
Thanks for the responses.
