I wrote a driver for the implementation of an I/O-module in the Com'X510. Now I found the following problems:
1. The names that I've used for the different Inputs are showed on the Device Settings page as element_ plus the Name I gave them in the driver and they are in alphabetical order instead of the order I programmed them in the driver:
Driver:
Device Settings:
2. It's not possible to see this device on the Monitoring or on the Measurement Table page.
Are these bugs or did I made a wrong manipulation?
Daniel
Posted: 2017-12-18 01:10 PM
Hi Daniel,
Can you attach an export of the custom model you're using?
Best,
Colton
