Gateways and Energy Servers
User | Count |
82 | |
46 | |
29 | |
28 |
Dear all,
We have tested integration of PowerTag, Smartlink Din and Com’X with Retail BU team located in Singapore successfully. Attached please find the link to the application note and drivers for the integration.
Please go thru the doc and let me know if you have any question.
https://schneider-electric.box.com/s/fx34v2oel9i2a8zmxgzwad4zy2y9kly3
Hi Chee,
doc not available to non SE personnel.
Grant
Hi All,
Have anyone tried to connect a Com'X with PowerTags using Zigbee? Is it possible?
Theren
Hi Lap,
They can't be connected directly.
You need either the power tag gateway or smart link sid gateway.
Cheers
Grant
Posted: 2017-09-22 07:44 AM
Could you advise how many (max) Powertag can be connected to Com'X? Thanks
Hi Jixing,
Respecting the memory capacity and processing of multiple Modbus slave devices you can have betwen 32 to 40x PowerTag max on one Com'X.
Hi All,
is it possible to use Ecoreach to configure Power Tags in the Smartlink DIN?
If yes, would be better to write the guide with this tool instead of Smart Test.
Regards.
Salvo
Hello @Salvatore Privitera,
I am L3 Expert for Ecoreach and it is possible to scan the and configure the PowerTags using Ecoreach. To see the complete list of devices integrated in Ecoreach, I suggest you refer the Ecoreach help file which is accessible from Ecoreach. You can download the latest version of Ecoreach from "ecoreach.schneider-electric.com"
Please let me know if you have further questions on Ecoreach.
Best Regards,
Kshitij.
