How can I replicate circuit segregation from BCPM EGX default device type when creating a custom BCPM device type?
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • How can I replicate circuit segregation from BCPM EGX default device type when creating a custom BCPM device type?
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
engenharia_memt
Lieutenant | EcoXpert Master engenharia_memt Lieutenant | EcoXpert Master
Posted: ‎2017-12-05 07:34 AM
1553
Figure 1 - Circuits segregated (Default device Type)
Figure 2 - Circuits NOT segregated (Custom device type)
Tags (6)
  • bcpm
  • custom devices
  • custom driver
  • custom_device
  • device_type_editor
  • egx 300
Replies 6
Hal_Etheridge
Janeway Hal_Etheridge Janeway
Janeway
Posted: ‎2017-12-05 09:46 AM
1500
The standard BCPM device driver already separates the values into circuit groupings.  If you have the latest firmware then it even reads the circuit configuration from the device and automatically groups using that data!
engenharia_memt
Posted: ‎2017-12-05 11:11 AM
1500
Ok! But I need to map a quantity that doesn't exist in the default driver. However, it is available in the modbus map, as you can see below.
Figure 1 - Default Driver
Figure 2 - Modbus Map (Integer Reg/Float Reg MSW/Float Reg LSW/R/NV/Meter/ModelBCPM/Description/ScaleReg)
How can I read this quantity (Apparent Power (kVA)) keeping the same structure of the default driver?
Thanks in advance!
Juan_Arias
Janeway Juan_Arias Janeway
Janeway
Posted: ‎2017-12-11 01:33 PM
1500
Leandro,
Are you asking about creating the driver in the EGX or in PME?
Juan
engenharia_memt
Posted: ‎2017-12-12 05:32 AM
1500
Hi Juan,
Actually I need to change the default EGX driver to add apparent power or create a new EGX driver that segregate BCPM souces in the same way as the first pictures.
Juan_Arias
Janeway
Posted: ‎2017-12-12 03:40 PM
1500
Hi Leandro,
Not an EGX expert. But here are a few potential useful links:
https://www.schneider-electric.ca/library/SCHNEIDER_ELECTRIC/SE_LOCAL/APS/207595_22AE/Custom_Device_...
Also try asking in the gateway community:
Gateways & Energy Servers
Juan
engenharia_memt
Posted: ‎2018-01-10 04:09 AM
Hi Juan,
I was able to run the circuits through ETL, segragate the devices and their respective quantities.
Thanks a lot for help!!
