Firmware Com'X 210 Version 2.1.17 -
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Firmware Com'X 210 Version 2.1.17 -
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
JamesJeanette
Commander JamesJeanette Commander
Commander
Posted: ‎2015-12-16 01:56 PM
Attention:
We have recently found an issue with the Com'X 200/210 version 2.1.17 firmware.  This does not affect the Com'X 510 version 2.1.17 firmware.
A solution for this problem has been identified and a new release is anticipated within days.
ACTION:
We recommend to not upgrade any Com'X 200/210 boxes to the 2.1.17 firmware.  There are no issues with using version 2.1.17 on a clean install (no prior configuration); however I propose that you wait for the upcoming release with the fix applied.
NOTE
If a user has already upgraded to the new version, they must not revert to the previous version nor should they make any changes to the Local IDs.  Doing so may require a factory reset which would delete the current Com'X configuration.  Additional instructions for the user to recover from the first upgrade to 2.1 will be provided with the new release.
Thank you
Updates:
  • Product and performance improvements
  • All Com’X models now use the same version number (2.1).
  • All Com’X models now share the same native Modbus gateway implementation.
  • Updated support for Schneider Electric Facility Insights development.
  • Improvements were made for Custom Device Type Models (bug fixes for Com’X 510)
  • Publication support for Weather Sentry™.
  • Protocol support: Zigbee Pro for Com’X 510 (to EM4300)
  • Ability to gateway to Zigbee device data by external Modbus TCP/IP clients. (All Com’X)
  • Monitoring support has been added for non-communicating equipment/sensors connected to the Com’X 510 digital inputs as well as ones connected to the variants of the Acti 9 SmartLink.
  • Firewall management support added to the Com’X 200/210 to match Com’X 510.
  • Corrected date/time format used in all languages which prevented accurate display of data
  • Incremental performance improvements aimed at reducing boot up time when configured, device discovery time, and device creation. Performance improvements targeted as priority in each new development cycle.
  • Additional bug fixes.
To be Updated.txt.zip
Tags (7)
  • 2.1
  • 2.1.17
  • com'x
  • com'x 210
  • comx
  • data logger
  • ebx210
Replies 0
