Attention:
We have recently found an issue with the Com'X 200/210 version 2.1.17 firmware. This does not affect the Com'X 510 version 2.1.17 firmware.
A solution for this problem has been identified and a new release is anticipated within days.
ACTION:
We recommend to not upgrade any Com'X 200/210 boxes to the 2.1.17 firmware. There are no issues with using version 2.1.17 on a clean install (no prior configuration); however I propose that you wait for the upcoming release with the fix applied.
NOTE
If a user has already upgraded to the new version, they must not revert to the previous version nor should they make any changes to the Local IDs. Doing so may require a factory reset which would delete the current Com'X configuration. Additional instructions for the user to recover from the first upgrade to 2.1 will be provided with the new release.
Thank you
Updates:
Hi James,
Do you have an ETA on the fix?
Colin
Hi Colin.
I am anticipating by the end of the week, but it depends on the testing effort. I will post it just as soon as I have it.
James
Any news on this? I have a customer waiting.
Kind regards, Michael
