Gateways and Energy Servers
User | Count |
82 | |
46 | |
29 | |
28 |
What are the newest features?
Hi James!
The Com'X 200 Version 1.1 will include a few new features including the firmware which will enable the Com'X as a gateway. This means that you will be able to use the Com'X as a pass-through gateway from a supervisory system such as PME to downstream devices. Also new in 1.1, you will notice a new tab named Custom Library. This feature will allow you to create custom device type models, with the ability to manage those custom models. You will have the option to also export, and import the models. Easier backup/save of your configuration is also improved in 1.1. Finally, there are also several new supported device types and product improvements.
We anticipate release of the new firmware by March 31st; however we are in final validation testing and will have confirmation next week.
I hope this helps.
James
Hi James,
Will SBO be able to read down stream devices also (like a egx)?
Can PME read the inputs on the comx?
