Standard for SF6 Gas in MV Switchgear
Expert on Demand for Standards & Regulations
Connect to Schneider Electric experts in your country for any inquiry about electrical installation and safety standards and regulations.
  • Power Distribution IEC
  • Standard for SF6 Gas in MV Switchgear
HelvinHermanT
Admiral HelvinHermanT Admiral
106
faisalamir
Lieutenant faisalamir Lieutenant
7
Dwinanto_Setyadi
Lieutenant JG Dwinanto_Setyadi Lieutenant JG
7
Back to Expert on Demand for Standards & Regulations
HelvinHermanT
Admiral
Posted: ‎2021-10-09 12:27 AM
1322
Question about SF6 Gas as insulation in MV Switchgear.
  • Indonesia
HelvinHermanT
Admiral
Posted: ‎2021-10-09 12:30 AM
Following your question about MV Switchgear with Insulation Gas :
The SF6 Gas is commonly used in Electrical Equipment worldwide, It is known for its Isolation performance & breaking performance. And it is a non-toxic gas.
The standard :
  • The use of SF6 for Electrical Equipment is confirmed & specified in IEC 60376 “Specification of technical grade Sulphur hexafluoride (SF6) and complementary gases to be used in its mixtures for use in electrical equipment”. This standard is prepared by IEC Technical Committee 10.
  • In IEC 62271-1 “High-voltage switchgear and control gear – Part 1: Common specifications for alternating current switchgear and control gear” :
    • The SF6 Gas is recognized as Non Oxidizing Gases with expected operation duration at least 20 years.
  • For Safety purpose, International Electrotechnical Commission (IEC) also release an international standard for Handling Procedures for SF6, please see IEC 62271-4 “High-voltage switchgear and control gear – Part 4: Handling procedures for Sulphur hexafluoride (SF6) and its mixtures”
  • Also in order to protect the environment, IEC also release a standard for the Re-Use of SF6 after recovery & reclaiming from Electrical Equipment (End of Life), IEC 60480 “Specifications for the re-use of Sulphur hexafluoride (SF6) and its mixtures in electrical equipment”
HelvinHermanT
Admiral
The standard :
