Apakah standar IEC untuk Busway / Busduct ?
Expert on Demand for Standards & Regulations
Connect to Schneider Electric experts in your country for any inquiry about electrical installation and safety standards and regulations.
  • Power Distribution IEC
  • Apakah standar IEC untuk Busway / Busduct ?
HelvinHermanT
Admiral HelvinHermanT Admiral
106
faisalamir
Lieutenant faisalamir Lieutenant
7
Dwinanto_Setyadi
Lieutenant JG Dwinanto_Setyadi Lieutenant JG
7
Back to Expert on Demand for Standards & Regulations
HelvinHermanT
Admiral
Posted: ‎2021-04-07 09:39 AM . Last Modified: ‎2021-04-27 06:50 AM
2100
@Nedi
  • Indonesia
  • bahasa Indonesia
HelvinHermanT
Admiral
Posted: ‎2021-04-27 06:50 AM
2061
Standar IEC untuk Busway / Busduct adalah IEC 60439-2 dan IEC 61439-6.
IEC 60439-2 terdiri dari 14 pengujian tipe & pengujian rutin.
IEC 61349-6 terdiri dari pengujian untuk kontruksi & performa untuk keamanan dan kehandalan. Terdiri dari 25 pengujian disain dan pengujian rutin.
IEC 61439-6 adalah standar terbaru dari Standar IEC untuk Busway / Busduct.
Untuk menjamin performa produk, pastikan produk mengikuti standar terbaru IEC 61439-6.
IEC 61439-6 25  :
10.2.2 Resistance to corrosion
10.2.3.1 Thermal stability
10.2.3.2 Resistance to abnormal heat and fire due to internal electric effects
10.2.4 Resistance to ultra-violet (UV) radiation
10.2.5 Lifting
10.2.6 Mechanical impact
10.2.7 Marking
10.2.101 Ability to withstand mechanical loads
10.2.102 Thermal cycling test
10.3 Degree of protection of assembly
10.4 Clearances distances
10.4 Creepage distances
10.5.2 Effective continuity between the exposed conductive parts of the BTS & the protective circuit
10.5.3 Short-circuit withstand strength of the protective circuit
10.6 Incorporation of switching devices and components
10.7 Internal electrical circuits and connections
10.8 Terminals for external conductors
10.9.2 Power-frequency withstand voltage
10.9.3 Impulse withstand voltage
10.10 Temperature-rise limits
10.11 Short-circuit withstand strength
10.12 Electromagnetic compatibility (EMC)
10.13 Mechanical operation
10.101 Resistance to flame propagation
10.102 Fire resistance in building penetration
  • bahasa Indonesia
HelvinHermanT
Admiral
2062
IEC 61439-6 25  :
10.2.5 Lifting
10.2.7 Marking
  • bahasa Indonesia
HelvinHermanT
Admiral
Posted: ‎2021-06-28 04:48 AM
In response to HelvinHermanT
UL 857 juga merupakan salah satu standar untuk Busway (UL Standard for Safety Busways)
@Nedi
