IT load properties
Energy system configuration
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • ITA: Energy Efficiency (on premises only)
  • Energy system configuration
  • IT load properties
  • Mark as Read
  • Ventilation properties
  • Lighting properties
  • Infiltration properties
  • Energy system properties
  • Energy efficiency properties
  • Configuring ventilation and lighting
  • Configuring infiltration
  • Configuring IT load
EcoStruxure IT Support
Request Support
Back to Energy system configuration
  • Mark as Read
IT load properties
Picard EcoStruxureIT
‎2020-04-23 05:41 AM
This section of the Properties dialog box, accessed by right-clicking an energy system or by clicking the relevant icon at the bottom of the energy system, provides relevant information that identifies this subsystem.
The information may vary based on the subsystem type. The IT load is a very dynamic value since it can change with the power consumption of each server in the data center. It will also change as servers are added or removed from the date center.
Configuration
Power path
Identifies whether the IT load is on the critical or primary power path. You cannot choose to exclude it in this energy system.
Calculation source
Identifies that the IT load is measured (live).
Script
Opens the script editor for editing scripts to retrieve IT load measurements.
