Configuring infiltration
Energy system configuration
Send InviteCancel
You can access and edit the data on the property tabs defining the configuration for infiltration by right-clicking an energy system and selectingPropertiesor by clicking the icons at the bottom of the Energy System pane. The configuration options vary based on the type of subsystem.
Right-click the energy system and select> Properties> Infiltration.
Define theDry bulb fixed lossto indicate the fraction of power that is lost per degree Celsius dry bulb.
Define the loss configuration inDry bulb fixed loss: type a number between 0 and 100, indicating the fraction of power lost per degree Celsius dry bulb.
