Configuring IT load
Energy system configuration
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • ITA: Energy Efficiency (on premises only)
  • Energy system configuration
  • Configuring IT load
  • Mark as Read
  • Ventilation properties
  • Lighting properties
  • Infiltration properties
  • IT load properties
  • Energy system properties
  • Energy efficiency properties
  • Configuring ventilation and lighting
  • Configuring infiltration
EcoStruxure IT Support
Request Support
Back to Energy system configuration
  • Mark as Read
Configuring IT load
Picard EcoStruxureIT
‎2020-04-23 05:35 AM
You can access and edit the data on the property tabs defining the configuration for IT load by right-clicking an energy system and selecting Properties or by clicking the icons at the bottom of the Energy System pane.
  1. Right-click the energy system and select > Properties > IT Load.
  2. Define the general settings for the energy system's IT load.
    1. Select if the IT load is on the critical or primary power path.
      IT load must be included for the energy system.
    2. IT load is measured (live).
  3. Use the Script tab for writing scripts that retrieve measurements.
