Welcome to the SEAL Community
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Welcome to the SEAL Community
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
Benji
Posted: ‎2024-11-21 04:31 PM . Last Modified: ‎2025-12-02 01:48 AM
68
19781
SEAL is a toolbox with a number of powerful utilities to help automate and ease tasks that are usually cumbersome and time consuming. It comes with an easy to use DWG to TGML converter, and a versatile Script utility, which gives the user full access to automate EBO engineering, after deploying custom or standard applications of your choice. For some countries it is also used to create applications for EBO, but while the Design part is only applicable for those countries, the rest of the SEAL application provides value and efficiency to the engineering process regardless of the standards and process being used.
It comes with scripts for EBO to BACnet object conversion, generating trend logs based on naming patterns, advanced bindings (many to many) or search and replace functionality, fully automated duplication of devices or folders to specified paths and a few other cases. In addition to that, expert users can obtain the possibility to create own custom scripts, which they can share with the Community.
Access to SEAL is automatic and based on partner status. All EcoXperts set up as Registered, Certified or Master will automatically be provided access when trying to log in. If you don't get access, please reach out to your Schneider Electric account manager to ensure your account is set up correctly.
For general SEAL training, visit MyLearning Link
Specific modules on MyLearning Link:
- Getting started with SEAL
- Create configurable EBO applications using SEAL Design
- Integrating devices seamlessly into EBO using SEAL Template Library
- Convert AutoCAD DWG drawings to EBO graphics using SEAL Dwg2Tgml
- Automate Smarter and Deliver Faster using SEAL Script
You can access SEAL here.
  • Announcements
  • Training
  • download seal
  • install seal
Replies 68
  • « Previous
    • 1
    • 2
  • Next »
Benji
Posted: ‎2025-06-18 02:49 AM
In response to bogado11
Please reach out to the team using the form you get when you try to download. It seems like a general platform issue, not related to our deliverable.
Vibarthe
Lieutenant | EcoXpert Master Vibarthe Lieutenant | EcoXpert Master
Posted: ‎2025-07-09 04:58 AM
1548
Hi Benji, could you please give me access.
Benji
Posted: ‎2025-07-09 05:15 AM
In response to Vibarthe
Hi @Vibarthe - access to SEAL is now fully automated, meaning that you're granted access automatically, provided that you're setup up correctly in mySchneider and registered to the right account. When I look at your contact in the backend, it seems that you're registered in a company, only having you as contact. That's obviously not the actual case, but that's how it's looking. Please get with your Schneider Electric representative, and have them clear up the structure.
As long as the company is registered as a EcoXpert Building Automation partner, everything is automatic.
S_CAMPEGGIA
Crewman S_CAMPEGGIA
Crewman
Posted: ‎2025-08-14 01:48 AM
1435
it possible to have an acces to SEAL , i'm Ecoxpert Schneider certified , and  integrator .
to discover and test it , to exploited this toolbox ?.
Thanks you.
I download the 1.15 but not possible to install on my computer ?
StefanLundin
Commander
Posted: ‎2025-08-14 04:07 AM
In response to S_CAMPEGGIA
@S_CAMPEGGIA  regarding acces, we've recently migrated SEAL to a fully automated solution, where access is automatically provided to users based on their partner status. All EcoXpert's being Registered, Certified or Master automatically gets access.
If you're an EcoXpert and unable to access the system, it's most likely due to an issue with the status on your Schneider account.
You should be able to view your account status on your MySchneider profile under Programs
Your profile should indicate that you are at a Certified Program Level of Registered, Certified, or Master. If it does not, your account may not be correctly configured as an EcoXpert partner. Please contact your account manager to resolve this issue.
Once your account details are correctly updated, access to SEAL will be granted automatically.
If there is an installation issue, its most certainly something local with your computer, we haven't got any reports that installation is not possible in general, ensure you got admin rights to your computer.
Olivier_Letourneau
Lieutenant | EcoXpert Master Olivier_Letourneau Lieutenant | EcoXpert Master
Posted: ‎2025-08-19 10:49 AM
1391
I'm unsure whether my account is eligible for access.
When I go to the area mentioned in the response above, this is what I see:
Interestingly, my colleague is able to access this area without any issues. Could this be because I don’t have the required certifications and therefore shouldn’t have access? Or, as you mentioned, is it due to my account not being configured correctly?
Thank you
Benji
Posted: ‎2025-08-19 11:33 AM
In response to Olivier_Letourneau
@Olivier_Letourneau the issue is indeed that you (together with 4 other contacts) are linked to a pseudo company in the backend systems, rather than the main account.
Please reach out to your SE representative. Once your contacat is linked to the right account, you'll get full EcoXpert Master access automatically.
eliasnord
eliasnord
Cadet
Posted: ‎2025-10-01 05:33 AM
Hey Benji. I do also not have access to SEAL with my account. Can you grant access? 🙂
StefanLundin
Commander
Posted: ‎2025-10-02 01:15 AM
@eliasnord  - It looks like your account isn’t currently recognized as an EcoXpert account. Please reach out to your Account Manager to have this corrected. Once updated, access will be granted automatically.
JamesD93
Lt. Commander JamesD93
Lt. Commander
Posted: ‎2025-10-04 09:28 AM
1163
Forgive me, as this may have already been answered.  I previously had access to the SEAL utility; however as of now when logging in, it says my account does not have access.  It has left me very confused.
Benji
Posted: ‎2025-10-05 04:59 AM
In response to JamesD93
Hi @JamesD93 - for context, SEAL access is automated based on account and status. That means that we just read the current status from the account you e.g. use for sing-on on mySchneider.
Your status is set to "Inactive" which would indicate that your primary contact at the company has changed the account status.
In short, you should get with your primary contact at your company, and have him enable your account.
KevinC.232
Lieutenant | EcoXpert Master KevinC.232 Lieutenant | EcoXpert Master
Posted: ‎2025-10-24 09:41 AM
800
Is there a way to obtain a list of SDK commands?
StefanLundin
Commander
Posted: ‎2025-10-24 11:17 AM
In response to KevinC.232
798
Hi @KevinC.232
If you go to this post you will find a link to the SDK documentation.
KevinC.232
Posted: ‎2025-10-24 11:45 AM
In response to StefanLundin
Thanks, Stefan. Sorry for the repost, I missed that one.
fella
fella
Cadet
Posted: ‎2025-11-20 04:08 AM
452
Hello, could you please grant me access to the SEAL app.
Thank you!
Benji
Posted: ‎2025-11-20 04:12 AM
In response to fella
451
Hi @fella - I'm not sure I follow. According to your information, you have access to SEAL. Have you downloaded, installed and started the application, and logged in using Single Sing-On? Do you get any error or message?
Benji
Posted: ‎2025-11-20 04:16 AM
Sorry @fella I can see now what is happening. Your account has the "Identified" level. Access to the application is granted to "Registered", "Certified" and "Master". In other words, once your account gets to the next level, access is automatic. Please get with your Schneider Electric account manager to discuss the level.
fella
fella
Cadet
Posted: ‎2025-11-20 04:19 AM
In response to Benji
449
I got this error message
Benji
Posted: ‎2025-11-20 05:00 AM
Thanks, as noted in the message, please get with you Schneider Electric account manager.
  • « Previous
    • 1
    • 2
  • Next »
