Warning when deploying to server
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Warning when deploying to server
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
LukasB
Ensign LukasB Ensign
Ensign
Posted: ‎2025-04-15 04:37 AM . Last Modified: ‎2025-04-15 04:42 AM
1023
I get this error when deploying to a PCT server.
Bindings and stuff like alarms contains broken references.
Plox help
SEAL för brandgasfläktar.zip
  • Design
StefanLundin
Commander
Posted: ‎2025-04-15 05:41 AM
1
954
@LukasB  - I found what went wrong, a new version of the library is published, open your solution again and you should be able to download it without any issues.
Replies 7
LukasB
Ensign
Posted: ‎2025-04-15 04:39 AM
1021
Tried to upload my dapps but got this error msg
Benji
Posted: ‎2025-04-15 04:40 AM
In response to LukasB
1020
@LukasB please zip the dapps file and attach it. For some reason, we're unable to add dapps as allowed file extension. Sorry for the inconvenience.
LukasB
Ensign
Posted: ‎2025-04-15 04:43 AM . Last Modified: ‎2025-04-15 04:43 AM
In response to Benji
1018
No problem!
Updated the post with the attached ZIP.
Benji
Posted: ‎2025-04-15 04:43 AM . Last Modified: ‎2025-04-15 04:52 AM
Thanks - I hope @StefanLundin or @Marco_Z can have a look.
StefanLundin
Commander
Posted: ‎2025-04-15 05:14 AM
I'm on it, I'll get back to you in a bit.
StefanLundin
Commander
1
955
LukasB
Ensign
Posted: ‎2025-04-15 07:05 AM
In response to StefanLundin
Worked just as you said, thanks!
