Unable to open .dapps file. Error loading solution.
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Unable to open .dapps file. Error loading solution.
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
Jim.T
Lieutenant JG
Posted: ‎2024-12-04 07:13 AM
586
when I try to open a .dapps file that I downloaded from this forum I get the error
"Error loading solution"
"Invalid DbItemReference, missing mapping for library [name of library]@[version]"
  • Design
Jim.T
Lieutenant JG
Posted: ‎2024-12-04 07:33 AM
it's great to see that you are curious about the .dapps files uploaded by other users, however, all users do not have access to all libraries. They are tailored to each country/zone and in this case your account is not from the same zone as the original creator. This is by design to avoid filling each users collection with libraries that are not relevant.
If that doesn't sound right, it might be because the solution file is based on a deleted library, however this should be exceptionally rare.
Jim.T
Lieutenant JG
