Template Library - Outdated import files?
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Template Library - Outdated import files?
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
Thronborg
Lieutenant JG Thronborg Lieutenant JG
Lieutenant JG
Posted: ‎2025-12-09 04:49 AM
148
I noticed there was a difference in the EVlink Pro AC import file between the SEAL-template library repository and the Schneider BMS-application repository: https://bms-applications.schneider-electric.com/type/MB/download/215
In the graphics you can see that the Seal version is a Pre-release version and the BMS-application is on version 2.3.
  • Template Library
Benji
Posted: ‎2025-12-12 03:09 AM
I've added the ADT from global so that both types are available
Benji
Posted: ‎2025-12-11 08:54 AM
Thanks for the feedback @Thronborg - this is not really about one being outdated, but rather than the zone one (in SEAL) was created first, and the one from global was created afterwards. We tried to sync who did what, but it didn't always work.
I think we'll include both in what is available in SEAL, and then you can select which one you want to use.
Benji
