This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Posted: 2024-12-11 04:42 AM . Last Modified: 2025-08-06 11:36 PM
New version 3.5.0,
I have modified the new powerful Search And Replace.
My version use EBO ISearch (Turbo) so it only works on EBO 4 and above.
I have included Word search with FPB syntax check. (to long name after rename and illegal char)
If Renaming FBP fail in this version SEAL will stop renaming all other components.
More information on renaming progress
NOTE: I have only tested a little 😏, so ....
Updated version 3.5.0 fixet search on object and properties
Posted: 2025-03-11 06:10 AM . Last Modified: 2025-03-11 06:13 AM
Looks great!
I just started using the ISearch myself to improve efficiency.
I really think this should be merged to the standard SaR script. @MortenEnger
A suggestion would be to add a server version check, to seamlessly change between ISearch and "standard child crawl".
An example from another script i have to check references, which was added in 3.2:
serverPath = await sdkClient.INavigate.RootObjectPath();
//Get servers software version
propertyValueSoftwareVersion = await sdkClient.IAdvanced.GetPropertyValueString({ propertyPath: serverPath.returnValue.fullPath + "/SWVersion" });
swVersion = propertyValueSoftwareVersion.returnValue.split('.').join("");
swVersionShort = parseInt(swVersion.substring(0, 2));
//Cannot check for references in software versions lower than 3.2
if(swVersionShort < 32)
sealScript.result("WARNING: Cannot check for references in software versions lower than 3.2");
skipReferences = true;
