This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Posted: 2025-12-01 02:13 AM
Hi Everybody,
Is anyone have an idea of my issue?
I have a right xml file for import data into a trend by seal script (ITrendLog.ImportLogRecords).
First test :
I used ES with seal script on the same PC, used my seal script and i have :
sauvé=487 means that 487 datas are right restored.
Second test :
I used same ES with seal script on A DIFFERENT PC, used same seal script and i have 487 datas rejected.
Then question is : Is there a difference for ImportLog if you are not in localhost for SEAL?
Posted: 2025-12-01 04:00 AM
Hi Benji,
There is no error in Seal only a return of ITrendLog who give you how many trend is done :
Then in localhost found=saved, in remote found=rejected.
Posted: 2025-12-01 03:00 PM
I'm just wondering if there's anyhing in Message when it fails?
Can you share the script you're working with?
Posted: 2025-12-02 11:53 PM
Is the remote server by any change a PCT? Because then I think that's why it's not working. The trend plugin isn't active in PCT, and you can't even import trend data manually in PCT.
Posted: 2025-12-03 01:19 AM
Hi Benji,
No,I know that.
i have an ES on PC1.
I installed Seal on PC1 and it works fine.
I installed Seal on PC2 (same datafile, same seal sccript, same connexion) doesn't work without any errors but return sdk said that data is rejected.
KR
Posted: 2025-12-03 02:02 AM
@MikaelBodereau on PC2 - can you do the same configuration using workstation installed on PC2, and using the same EBO account as you use when you log in to the ES in SEAL?
Posted: 2025-12-03 03:00 AM
Hi @StefanLundin ,
yes all is the same. (version 1.8.1 also, same issue).
I disabled trellix (SE software) even if i can connect to my remote ES without issue.
I tried to use 192.168.1.22:87 instead of localhost for PC1 and it works fine (localhost or ip address on PC1 SEAL access)
I tried to use 192.168.1.22:87 on seal PC2, connexion is ok but data are rejected.
Posted: 2025-12-07 10:13 PM
Hi @MikaelBodereau is both PC setup with total same "Language & region". Don't know if it help, but know that "." and "," are used different, it can make some errors
Posted: 2025-12-07 11:38 PM . Last Modified: 2025-12-07 11:38 PM
Hi @JohnnyCarlsen, thanks for help but i check and both are with ','. Then issue is always true.
