This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Posted: 2025-10-27 03:04 AM . Last Modified: 2025-10-28 05:29 AM
We’re excited to announce SEAL 1.18—a release that marks a significant step forward for engineering teams working in secure or restricted environments. With this update, SEAL Script can now be used on locked-down sites without internet access, thanks to a new time-limited offline license option (initially available for the Nordic zone). As always, we encourage you to read the full release notes for all details.
Offline Script Execution:
SEAL Script can now run on locked-down sites using a time-limited offline license, supporting critical workflows even without internet access (initially available in the Nordic zone).
Automated Graphics Library Management:
SEAL Design now allows for automatic download and configuration of TGML component libraries, ensuring you always work with the latest standards—no manual setup required. (More details about this function in this post.)
EBO SDK Update:
Compatibility with EBO SDK 7.0.3 for improved performance and reliability.
👉 Download the updated installer here.
👉 Read the full release notes here.
We hope these updates make your work with SEAL even smoother. As always, your feedback is welcome!
Posted: 2025-10-27 04:36 AM
Probably worth mentioning that as part of the update of the SDK, we've also implemented a change which makes it possible to connect to servers in locked down environments where the "ping" command has been disabled - in other words, we enabled the new feature in the SDK 7.0.3
Posted: 2025-10-27 06:23 AM
Will the Library be updated more often now? I wish that more (read all) of the new components should be included in the library. For example more notification icons, drawer objects and other objects from different Widgets etc.
Posted: 2025-10-27 08:01 AM
I get this when trying to open a project:
Posted: 2025-10-27 08:38 AM
@erik_ogren_cbkab That's more of a library issue, not 1.18 related as such. I'll PM you and we could have a look at your solution.
Posted: 2025-10-27 09:24 AM
Since you're referring to the Swedish Component Library used in Design, I’ll respond from a Swedish standards perspective.
Our main goal is to ensure that all components present in the Swedish Design Libraries are also available in the TGML Component Library. Whenever we add new components to the libraries, we also aim to include them in the TGML Component Library as well. Some of the components that were previously missing have been added to the new library you receive via SEAL.
However, I’ll make a note that some components are truly missing from certain categories—such as InfoButtons and Drawer—and we should work on updating those to reflect what’s currently included in the libraries.
Posted: 2025-10-31 03:28 AM
I'm not 100% sure it's because of this update, but my SEAL window becomes blank and glitchy after a 5-10min, requiring me to restart it. Weird.
Posted: 2025-10-31 05:25 AM
Hi @NiilaM
That was an unusual behavior..
I assume you’ve already tried reinstalling SEAL. Please also check that your Windows and Microsoft Edge are fully updated.
If the issue persists, kindly report it through the Technical Support channel so we can assist you you more thoroughly there.
Posted: 2025-11-03 04:40 AM
Nope, reinstallation did the trick. I'll let you know if this happens again. Apologies and thanks!
