Object Binder - Fault Generating binding CSV
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Object Binder - Fault Generating binding CSV
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
18
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
Phuc10
Crewman Phuc10
Crewman
Posted: ‎2025-10-01 09:29 PM
6
735
Hi everyone,
I have a problem when select mode "Generate binding CSV"
The output file .csv doesn't match the instructions
Folder From.pngFolder To.pngObject Binder file csv.pngObject Binder configure.png
  • Script
APA
Lieutenant APA Lieutenant
Lieutenant
Posted: ‎2025-10-01 11:36 PM
1
701
Hi @Phuc10
I have attached a version with fixed list separator in CSV generation. Could you test if everything is working for you?
Object Binder-1.1.0.sealscript.zip
Replies 6
Benji
Posted: ‎2025-10-01 09:54 PM
1
724
It seems there's something off with the header. Don't know if it's related to list separator. @APA / @Jim.T do you have an idea what's going on here?
@Phuc10 can you share the CSV file you've created? I have a feeling that it could work by just changing the list separator in the header.
Phuc10
Crewman Phuc10
Crewman
Posted: ‎2025-10-01 10:01 PM
In response to Benji
I attached the CSV file below.
APA
Lieutenant
Posted: ‎2025-10-01 11:16 PM
It seems to be list separator issue in headers. I'll look in to this.
APA
Lieutenant
1
702
Hi @Phuc10
Phuc10
Crewman Phuc10
Crewman
Posted: ‎2025-10-02 12:06 AM
In response to APA
Hi @APA,
It's working properly.
Thanks for your help!!
Benji
Posted: ‎2025-10-02 12:42 AM
Thanks @APA, until we get your role fixed, please get with @StefanLundin to make sure we get it updated.
