New feature V1.15 infotext
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • New feature V1.15 infotext
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
16
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
APA
Lieutenant APA Lieutenant
4
Back to EcoStruxure SEAL Forum
MikaelBodereau
Lieutenant MikaelBodereau Lieutenant
Lieutenant
Posted: ‎2025-06-02 07:51 AM
3
483
Could you explain me what i'm doing wrong with new feature infotext ?
Here is the code :
Here is result :
It always doubled...
Is it a bug or code i found in release notes is wrong?
  • Script
Jim.T
Lieutenant JG
Posted: ‎2025-06-02 08:14 AM
1
474
Hello! You've encountered something that we forgot to test for.
Strictly speaking your hierarchy is wrong, but it is still our responsibility to inform you of that and not display such confusing results. We'll make sure that it becomes clearer in future versions of SEAL.
To achieve what you probably want you should follow the recommended hierarchy of 'Parameters => Groups => Items', here's an example of correct usage that does not create duplicates:
Jim.T
Lieutenant JG
1
475
StefanLundin
Commander
Posted: ‎2025-06-02 08:25 AM
Internal reference #18923
Benji
Posted: ‎2025-06-02 10:08 AM
In response to Jim.T
As per @MikaelBodereau's example, there's definitely a use case for the "standalone infotext"... but then again, that will then be the equivalent of a group 🙂
