Getting generated files without deploying to server
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Getting generated files without deploying to server
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
Jim.T
Lieutenant JG
Posted: ‎2024-12-04 06:01 AM
630
Hi!
I have a solution made in SEAL Design that I can't deploy directly to the intended server. I would like to export the solution so that I can import it to the device when I have access to it.
  • Design
  • download tgml
  • tgml
Jim.T
Lieutenant JG
Posted: ‎2024-12-04 06:02 AM . Last Modified: ‎2024-12-04 06:03 AM
Hello, thank you for your question.
Currently there is no way to export the entire solution as it would have been deployed to a server, however, if you can connect to a device using Workstation you can also connect using SEAL! When in the same stage as you would have imported, connect using SEAL instead and deploy your solution.
If you really need the export, you’ll have to deploy to a dummy server and export using Workstation.
Lastly, you can download a few resources using the “documents” and “preview” buttons in the top right corner when in the “Applications” view.
Jim.T
Lieutenant JG
