BACnet Expose - SEAL Script
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • BACnet Expose - SEAL Script
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
StefanLundin
Commander
Posted: ‎2025-01-14 10:41 PM
7
2067
Introducing the SEAL Script: BACnet Expose
We are excited to share the SEAL Script named BACnet Expose, a collaborative effort by script experts from five countries within our community. Initially created in 2021 and updated in May 2022, this script automates the process of exposing EBO applications on BACnet, addressing the need for open systems and reducing manual, error-prone operations.
Key Features:
  • Automation: Converts EBO applications to BACnet, moving functionality and bindings to corresponding BACnet objects.
  • Compatibility: Supports various object types like IO, values, and schedules, with some limitations (e.g., alarms, trend logs).
  • Flexibility: Designed to handle different standards and structures across countries, though some manual adjustments may be needed.
Limitations:
  • Does not support entries on time schedules and calendars.
  • Does not support alarms.
  • Does not support trend logs.
Important Note: This script is a community-driven project and is not a guaranteed fully functional script. It is not shared as a standard script in the tool due to its collaborative nature and ongoing development. We encourage users to contribute and help improve the script further.
Disclaimer: This script is invasive and will make significant changes to the EBO database. It is therefore critical to make a BACKUP of the EBO server before running this script. It is also strongly recommended to do a dry run to evaluate if changes to EBO can be made to simplify the conversion to BACnet objects.
Usage:
  • The script performs a full conversion, creating BACnet objects and moving bindings and contents from EBO objects.
  • A dry-run feature is available to report convertible objects before making changes.
  • Generates a report on conversion failures for manual adjustments.
For detailed information, please refer to the attached script and manual.
Shoutout: A huge shoutout to the users Morten Enger, Christian Granberg, Enzo Dino Di Gregorio, Johnny Carlsen, Magnus Kennedy, Marcus Gilbert, Mikael Bodereau, and Morten Bjørndal for their incredible contributions to this project!
BACnet Expose - 1.2.0.zip
  • Script
  • Shared Scripts
Replies 7
Richard_Stark
Lieutenant JG Richard_Stark Lieutenant JG
Lieutenant JG
Posted: ‎2025-01-21 12:01 PM
1983
Can this script be modified easily to expose all of the same object types to BACnet without the binds translating and keeping them the same on the EBO side?
MortenEnger
Lieutenant MortenEnger Lieutenant
Lieutenant
Posted: ‎2025-01-22 03:34 AM
In response to Richard_Stark
If you are thinking like checking a box on EBO objects to expose them on BACnet without moving the objects or bind between BACnet and EBO object the answer is no.
This is sadly not supported by EBO.
Richard_Stark
Lieutenant JG
Posted: ‎2025-01-22 06:18 AM . Last Modified: ‎2025-01-22 06:20 AM
1931
I am thinking just mirroring the objects in the BACnet application folder to expose them to a third party or similar, but not moving all the bindings from the EBO objects to the BACnet objects (scripts bindings, etc). Effectively the EBO side stays the same, but a bind is added from the EBO object to the BACnet object in the BACnet application folder.
MortenEnger
Lieutenant
Posted: ‎2025-01-23 02:52 AM
If you just want a read-only mirrored copy on BACnet then a SEAL Script could generate those objects and make a one-way binding, but still limited to only a few kind of objects that can support this like variables.
Richard_Stark
Lieutenant JG
Posted: ‎2025-01-29 07:44 PM
Excellent. Yes that is fine. I am just thinking of a nice quick way to expose basic variables.
AlexBanguis
Crewman AlexBanguis Crewman
Crewman
Posted: ‎2025-07-30 07:03 PM
1
902
hey guys, upon using this script on a test bench i ran into the below error:
Script failed: 'Error: alert() has been disabled. Use 'await sealScript.alert()' instead.' line: 61
is that a matter of finding and replacing all use of alert() to "wait sealScript.alert()"
Benji
Posted: ‎2025-08-05 03:49 AM
In response to AlexBanguis
Thanks @AlexBanguis, @StefanLundin can you get the script updated and update the post?
