Application names including dot (.)
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Application names including dot (.)
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
18
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
erik_ogren_cbkab
Ensign erik_ogren_cbkab
Ensign
Posted: ‎2025-09-25 05:45 AM
379
When generating applications from SEAL with names including a dot (.) you loose all bindings to IO's.
  • Design
  • Swedish
Replies 4
erik_ogren_cbkab
Ensign
Posted: ‎2025-09-25 05:57 AM
And also the outdoor temperature name in the function block program is corrupted
StefanLundin
Commander
Posted: ‎2025-09-25 08:18 AM
Thanks for reporting this — we'll investigate and get back to you once we've looked into it.
StefanLundin
Commander
Posted: ‎2025-09-25 11:21 AM . Last Modified: ‎2025-09-25 11:22 AM
366
@erik_ogren_cbkab I think I somewhat solved it for the IO bindings.
The problem with the outdoor temperature name in the Function Block program stems from EBO not supporting dots (.) in the label of a block. When the outdoor temperature is sourced from another system, the external system ID gets included in the label of the input block — so if that ID contains a dot, it breaks the FBP.
For now, our solution is to restrict the user to using dots in the system ID of the outdoor temperature (unless it’s part of the local system ID).
Regarding the IO binding issue: I’ve added the fix to the most commonly used libraries. If there are specific libraries you need this for, let me know and I’ll prioritize adding the fix to those as well.
erik_ogren_cbkab
Ensign
Posted: ‎2025-09-29 07:26 AM
In response to StefanLundin
Thank you!
I have manually repaired all the bindings already but good thing you fixed them for future implementations 🙂
